Reply
My CBR750 is set to log everything but logs only the web logins to the router!
scalesremoved
Message 1 of 4
Guru
Re: My CBR750 is set to log everything but logs only the web logins to the router!
Something to contact NG support about to see what you should be seeing.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 4
scalesremoved
Hey! Thanks FOR NOTHING!
Message 3 of 4
Guru
FYI, forums can't always solve problems and some of us don't have this model product for experience so what we refer users to NG support as they would be best to look as this and you can let them know whats going on.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 87 views
  • 0 kudos
  • 2 in conversation
Announcements
