- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI CBK752 drops VOIP calls every few minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had ORBI CBK752 for about a month and VOIP calls over Zoom, Webex, WhatsApp etc continue to drop every few minutes. Changed a few setting after calling support 3 weeks ago and it worked for a while now it is back to the same issue. Searching in the forum results in VOIP issues going back 3 years but no meaningful steps to resolve. Any advice is greatly appreciated. Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI CBK752 drops VOIP calls every few minutes
Does this happen with only wireless connections or does it happend on wired connections as well?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Traffic Meter ,IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
https://community.netgear.com/t5/Orbi-AX/RBK753S-update-Rock-solid-in-terms-of-speed-and-stability-s...
