- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI CBR750 requires manually releasing/renewing the IP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI CBR750 requires manually releasing/renewing the IP
Internet dropped again. I released/renewed and called support again.
I waited for about an hour of the phone, wasn't connected to any support people, and once internet dropped again, the call failed, because I am using wifi calling.
Waited an hour for nothing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you factory reset and setup from scratch the CBR updating FW?
Try back tomorrow during the day and if you can, don't use wifi calling.
Try reaching out to a forum Moderator as well.
You may have a faulty CBR that needs replaced. I'd ask about a RMA option if thats availalbe to you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I called support today again. The support person reviewed the case and tried to contact Tier 2 support for 40 minutes. After that, I was told to drop a call and wait for a callback within the next two hours as Tier 2 is very busy. One more hour wasted, no solution to the problem.
No one called me back during the day.
I called Amazon, and they agreed to take the item back but charging me $81 restocking fee. I think I will go for it. I can't afford to spend more time with support figuring out this problem.
I purchased another modem today, this time I bought whatever is in Xfinity supported list. And I purchased Asus router. Hoping this will work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I ended up bying Motorola MB8611 modem and ASUS WiFi 6 Router (RT-AX3000). Netgear support is horrible. I calculated total of 14 hours spent on the phone without any luck. Support people just try some lame steps, and than they promise you to call later. And than they call later, and do some more lame steps. From my experience, none of the support people understood the issue in depth - even tier 2 support. The only difference for tier 2 guy was that he used TeamViewer to remotely access my laptop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ALL users need to make contact with NG support if your having FW problems with your CBK systems. NG support or engineering do not visit or post in forums or make anyone aware here of future updates.
https://my.netgear.com/support/contact.aspx
@rmarcare wrote:
Thank you both for the background, I’m trying to determine my next steps. Maybe a new FW update will come out soon?
- Mark as New
- Bookmark
- Subscribe
- Permalink
is reverting back to FW v3 a viable option that actually resolves the intermittent wifi issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not officially supported.
However you can try this:
Not sure if that would work or last as the CBR would problaby auto update back to v4.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Purchased combo router/modem Oct '21 and in the past 2 or 3 months, connectivity drops 4 or 5 times a day requiring a reboot. I updated to the latest firmware v4.6.5.8.
I had Spectrum out here yesterday to test the line and everything looks good on their end. I've used Orbi products for the past 6 or 7 years and never had a problem until I purchased this current model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RBR750 / RBS750 Firmware Version 4.6.7.13 Released
No, you have the CBK750 system which includes the CBR and RBS. All of which have a separate forum for. Please post there.
The CBK and RBK are two different systems.
Please contact NG support and let them know what your experiencing as any fixes will need to come from NG.
There's nothing here in the forums we can do in regards to that.
Thank you.
@atejwani wrote:
There are clearly issues with
- CBR750
- RBS750 (Does my thread not belong here)?
Secondly, the only solution I can think of is the firmware fix by Netgear - none of the hacks/tweaks work - they rather cripple capabilities.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 - Let's decompose RBK750.
Does RBK750 not include?
- RBR750
- RBS750
And hence, my issue in this forum?
Also, contacting Netgear Support will entail buying extending support, and at the end of the day
Netgear Engieering/R&D has to deliver working firmware!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have the CBK system which comprises of the CBR and RBS.
All CBR and CBK which includes an RBS are handled in the Orbi with cable modem forum. Please post there and contact NG support.
We don't get if or when that will happen. You'll need to contact them.
Thank you.
- RBR750
- RBS750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Satellite suddenly not connecting
I had the same issue upgrading RBS to firmware version V4.6.7.13 and all hell broke loose!!! I too have CBR750 firmware version V4.6.5.8_2.0.54.
I rolled back RBS to firmware V4.6.7.5. Now it is manageable, however nothing like the stability/performance I had August 2021, at which time Netgear introduced firmwares for CBK752 (CBR750 + RBS750) and every update after that is a joke, especially from the CBR750 + RBS750 perspective!!!
@imssh , @FURRYe38 @plemans , @Evans720 , @Blanca_O , @DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
im running CBK752: CBR750 on v4.6.5.8 and RBS750 on v4.6.7.5, so not quite sure about the requirement for both CBR and RBS to be on same FW. in fact, the prior latest RBS FW release was v4.6.5.14 which does not match v4.6.5.8
has there been any stable beta FW released for CBR that effects intermittent wifi issues? I see there have been several more 1 star reviews posted on netgear.com with regards to the CBK752 @atejwani
- Mark as New
- Bookmark
- Subscribe
- Permalink
The versions are not fully the same however are on the same base version: v4.6.5.14 which does match v4.6.5.8 and matters here.
