Reply
Highlighted
Orbi. CBR40 connecting to Xfinity
Comcast Xfinity does not recognize the CBR40 in wireless setup. Does anyone have a suggestion for now to do the setup? I'm surprised that this model isn't listed. What is Her head doing to have this added to Xfinity?
Message 1 of 5
Accepted Solutions
Highlighted
NETGEAR Moderator
Re: Orbi. CBR40 connecting to Xfinity
Hi @parends
Welcome to NETGEAR Community!
Here's the reference link of how to setup CBK40 : https://kb.netgear.com/000057114/
This device is compatible with xFinity
What Internet service providers (ISP)s are compatible with my Orbi Cable WiFi System?
Blanca
Community Team
Message 5 of 5
All Replies
Highlighted
Guru
You need to contact Xfinity ISP and have them help you set up the CBR40. I believe they support it.
Set up the CBR40 using a wired PC and web browser is best.
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 5
Highlighted
Thank you for your response. Xfinity did indeed set up the CBR40 for cable TV.
Message 3 of 5
Highlighted
Guru
Well the CBR40 doesn't provide cable TV services. It will provide video streaming services thru the CBR40 to a wifi connected TV.
Message 4 of 5
Highlighted
NETGEAR Moderator
Hi @parends
Blanca
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4012 views
  • 0 kudos
  • 3 in conversation
Announcements
