Reply
Highlighted
Orbi connects to R7000 for openvpn client
As Orbi do not support openvpn client, I plan to connect orbi with R7000. I found some ideas from below link.
https://community.netgear.com/t5/Orbi/Netgear-Nighthawk-R7000-and-Netgear-Orbi/td-p/1424315
I would like to know is there any configuration I need to pre-set in Orbi base and satellite
The R7000 wifi is closed. Should I configure the wifi setting in orbi base? Or I can simply connect a cable to orbi base and everything fine?
Message 1 of 4
Highlighted
Guru
Re: Orbi connects to R7000 for openvpn client
Please post about this here:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Also:
https://community.netgear.com/t5/Orbi/Orbi-OpenVPN/m-p/1278053#M6825
https://community.netgear.com/t5/Orbi/OpenVPN-Not-connecting-in-Orbi-system/m-p/1667377#M45913
https://community.netgear.com/t5/Orbi/Orbi-and-OpenVPN-cannot-resolve-computer-name/m-p/1504540#M234...
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 4
Highlighted
Thanks. I also want to add EX7500 into my network.
May I ask more about your setup?
Modem ->(cable) R7000 -> (cable) orbi  -> (mesh wifi) orbi / ex7500
Sorry I am newbie of network installation.
Message 3 of 4
Highlighted
Guru
You should only need the Orbi system for your wifi needs. EX7500 shouldn't be needed.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 573 views
  • 0 kudos
  • 2 in conversation
Announcements
