- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Possible to designate devices to use a specific satellite...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
Is it possible to designate certain devices to specifically default to the Orbi satellite rather than the main modem/router?
My son is a gamer and his room is a little closer in distance to the satellite, but all of his devices default to the modem/router.
My assumption and fact gathering online points to "No", but I wanted to see if I am missing something.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Possible to designate devices to use a specific satellite...
You can't. You can try this. Turn down the power out put of the CBRs wifi radios to help some. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apologies if this is a repost, but I'm not seeing my original reply...
@FURRYe38 . The distance is just under 30 feet.
I've attached a screenshot.
Do I adjust the radio power for the 2.4 or the 5G? Both the modem and the satellit operate on 5G mostly.
If I lower that one, would that affect all the devices connected to 5G?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try moving the RBS a bit farther out.
You can adjust either radio out put. It won't effect the other if you leave the other radio output alone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, it is already as far as it can go in my home. 'Farther out' would be outside. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, turning down the power on the RBR should help some.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Will try that. Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
