Orbi WiFi 7 RBE973
Reply
RBK50 vs CBR40
cordcutters
Tutor
RBK50 vs CBR40
Is the RBK50 just a CBR40 + an extender?
Reason I ask is, my cable provider only lists CBR40 as approved. Cannot find CBR40 anywhere to purchase.
If we buy the RBK50, will that work on our cable provider's network as it looks like it's 2 separate devices - a modem/router and an extender.
Confirmation of this would be VERY helpful!
Thanks in advance!
Message 1 of 4
Accepted Solutions
Guru
Re: RBK50 vs CBR40
The CBK40 is a RBR with a built in cable modem. This will ge a gateway modem with built in router and wifi. The RBK50 is a router and wifi only and requires the use of a ISP modem or ONT to get it's internet services from. There is no built in modem with the 50 series Orbi.
Message 2 of 4
All Replies
Guru
Re: RBK50 vs CBR40
Message 2 of 4
cordcutters
Tutor
Re: RBK50 vs CBR40
Thank you for the clarity much appreciated!
Message 3 of 4
Guru
Re: RBK50 vs CBR40
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1493 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
