Orbi WiFi 7 RBE973
Reply
RBR50 use as a sattelite
bubbadacat
Follower
I know this has been asked but I cannot find the answer.
I have a RBR50 system with two satilites.  I recently moved and needed to hook up to Xfinity via a cable modem so I purchased the CBR40-100NAS.  It works great with the two original  satilites.  Now I have the old but still good RBR50 home base that I don’t know what to do with.  I do have a separate, one room “casita” at my new home that needs a satilites (wi-fi /Internet).
Can I use the RBR50 base as a satilites with the new cable modem?  OR, is there another alternative to use the old base station to get wi-fi (internet) to my separate room which is only 10 feet from my main house?
Thank you.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Accepted Solutions
Guru
Re: RBR50 use as a sattelite
RBR units can't be used as satellites, only as main host routers or main AP mode only.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1496 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
