Orbi WiFi 7 RBE973
Reply
RBS20 Satellite Firmware Update Issue on iPhone App
PumpkinPatch
When I open and minimize the Orbi app on my iPhone 11 and reopen it, it shows the RBS20 satellite requires a firmware update. I have manually updated the firmware, via download, on the satellite twice but the app still indicates an update is required. However, if I check the status of the firmware with a web browser, it shows the firmware is up to date: 2.5.1.16. The CBR40 firmware is 2.3.5.12. Anyone else have this issue?
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 4
Guru
Re: RBS20 Satellite Firmware Update Issue on iPhone App
I would post about this over in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
If the RBS is fully updated along with the CBR, then I would skip the notification on the app.
Message 2 of 4
PumpkinPatch
Thank you!
Message 3 of 4
Guru
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1058 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
