Orbi WiFi 7 RBE973
Reply
how to set up two orbi WIFI systems, one at both home and cottage....can i do both with my phone?
TamboKT26
Follower
i have an orbi WIFI system at home (CBK40). i now want to set up an orbi at our cottage an hour north. Can i do so with same account and with my same phone?  i would like to be able to remotely control both my home WIFI and cottage WIFI. Haven't set up the cottage WIFI yet but will do in the next 24-48 hours. Thanks.
Message 1 of 5
Guru
Re: how to set up two orbi WIFI systems, one at both home and cottage....can i do both with my phon
I haven't done this, however I presume you can have more than one setup configured with the app. You would need to be at the location during setup.
Something you might ask NG support first to ensure this is supported.
@vkdelta
Message 2 of 5
vkdelta
NETGEAR Expert
Possible but there are some limitations such as Alexa/google features dont work with multiple Orbis.
App will show 2 of them and you can choose based on Model/SN.
yes, you will need to set it up from specific location first. You cannot do first setup remotely.
Message 3 of 5
ekhalil
Master
You will see all your systems (with the status of each) in the app and you can switch between them as follows:
Message 4 of 5
Guru
Any updates on this?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2748 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
