Orbi WiFi 7 RBE973
Reply
2.0.0.72 orbi satellite dropped
cinek
Apprentice
was hoping the latest firmware would fix things but my satellite just dropped off. Can't connect to it at all even when using a desktop wired to the router.
Message 1 of 6
Re: 2.0.0.72 orbi satellite dropped
My god, still no ethernet backhaul ?!
Plus what is a "daisy chain" ?!!
Message 2 of 6
rhester72
Virtuoso
Satellites connecting through nearer satellites versus further routers (i.e. multi-hop).
Rodney
Message 3 of 6
cyberprashant
Luminary
perhaps satellite too far from the base (out of range?).   Try add a satellite - I had to do that to add back in my satellites after the upgrade and do the whole sync thing.
Message 4 of 6
Ely
Luminary
Luminary
Perhaps your satellite is too far? have you tried placing it closer to the main Orbi unit?
Message 5 of 6
cinek
Apprentice
I don't think it's too far as the ring doesn't light up. I had this happen on a few occasions and it's now closer to the router. Also the satellite still gives out full wifi signal but none of my devices are able to obtain the IP address. If I turn off the sattelite the main router reaches the end of the room (about 10m further than the current sattelite) but the speeds are a lot slower due to the weaker signal. I am running orbi in AP mode. Not sure if this makes a difference. I can try setting it up in router mode and get rid of my ISP router
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2181 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
