- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
2.5.1.16 Results Only
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2.5.1.16 Results Only
Do you have just 1 RBS or do you have more?
@changds wrote:Correction: same as before (2.5.1.16 vs. 2.5.1.8) - the RBS50 satellite still periodically reboots itself (blue ring appears for several minutes while wi-fi is down).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well on my RBS50Y, I regenerated the passkey, reconnected and the unit synced with a good connection.
5 minutes later, shows disconnected.
Once again, nice work Netgear - NOT.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the suggestions! Some more details on the setup: 1) using wired backhaul between router and satellite (only 1 satellite), 2) 2.4 GHz is on channel 6 / 5 GHz is on channel 48 (both of these are the least crowded in my neighborhood), and 3) did a factory reset and reboot on router and satellite. I think I've tried everything in the bag of tricks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend you contact NG support and file a suport ticket on the RBSY. The FW needs to be updated on the RBSY to ensure it works correctly with new Orbi FW v16.
https://www.netgear.com/support/#
@steve8411 wrote:Well on my RBS50Y, I regenerated the passkey, reconnected and the unit synced with a good connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you turn down the power for the radios on the RBR to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Does the RBS keep rebooting if you bring the RBS in the same room with the RBR?
@changds wrote:Thank you for the suggestions! Some more details on the setup: 1) using wired backhaul between router and satellite (only 1 satellite), 2) 2.4 GHz is on channel 6 / 5 GHz is on channel 48 (both of these are the least crowded in my neighborhood), and 3) did a factory reset and reboot on router and satellite. I think I've tried everything in the bag of tricks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since updating to v2.5.1.16, I am having brief moments of network disruption experienced by all devices on the network. My husband and I will be on our laptops while music is streaming on our tv and all devices will experience a brief period of no connectivity. All devices show full strength connectivity before the interruption. Sometimes the devices still show connection to the network even though no data seems to be flowing. In these times, I try to connect to Orbi's admin page, but cannnot reach it. When I am able to get data again and view the Orbi logs, I will see the reconnection of devices immediately after the momentary connection blip, which suggests the devices did indeed lose connection. I have not had any connection issues in the 3 years of owning the Orbi and there have been no new devices added to the network in the last few months. Something is broken, but I don't know what.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We experienced the same thing. Our RBS50 satellite seemed to be the culprit and bring down the whole network for 5+ minutes while it rebooted. After multiple attempts at firmware changes, gave up. Bought the SRK60 Orbi Pro (which runs on different firmware) and has been stable for 8+ days so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Appreciate the advice and suggestions. Tried a few different configurations, but the Orbi RBS50 satellite kept rebooting. Installed the Orbi Pro SRK60 (running V2.5.2.104) last week, and the router/satellite has been continuously up, connected, and stable for 8 straight days. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the back reset button for 15 seconds then release.
@changds wrote:We experienced the same thing. Our RBS50 satellite seemed to be the culprit and bring down the whole network for 5+ minutes while it rebooted. After multiple attempts at firmware changes, gave up. Bought the SRK60 Orbi Pro (which runs on different firmware) and has been stable for 8+ days so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.7.0.70 seems stable
Ironically, the Orbi Pro SRK60 was intermittently dropping after a power outage, so I switched back to the Orbi RBK50 (with firmware upgraded to 2.7.0.70 - https://www.netgear.com/support/product/RBK50.aspx#download). The first couple of reboots, the RBK50 still wasn't staying up, but after a modem reset (which I wouldn't have thought would make a difference), the system has been up for the last 12 hours or so.
P.S. I now have an extra Orbi Pro SRK60 that I'm not sure works anymore.
@changds wrote:Appreciate the advice and suggestions. Tried a few different configurations, but the Orbi RBS50 satellite kept rebooting. Installed the Orbi Pro SRK60 (running V2.5.2.104) last week, and the router/satellite has been continuously up, connected, and stable for 8 straight days. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2.7.0.70 seems stable
My RBK50 has been doing well on v70 as well:
Basic Information | ||
CPU Load | 25.5474% | |
Memory Usage(Used/Total) | 148MB/495MB | |
Flash Usage(Used/Total) | 2955MB/4096MB | |
Network Session(Active/Total) | 162/65536 | |
System Uptime | 05:19:59:08 |
- « Previous
- 1
- 2
- Next »
