Orbi WiFi 7 RBE973
Reply
5G Signal Pulsing
mercadj
Follower
5G Signal Pulsing
Is Anyone having issues eith their router disconecting wifi? i am also having an issue with my 5g signal pulsing. If i use a wifi analyser i can see my signal pulsing or dropping and rising. getting frustrated with this router and may be time for a brand change. i have the latest firmware update on router and satalite. frustrating!!!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: 5G Signal Pulsing
Has a factory reset and setup from scratch been performed on the RBR and RBS?
How long have you had the system?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 641 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
