- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1200 RBK13 Mesh Router Buffering when streaming Netflix and Amazon Prime
- Mark as New
- Bookmark
- Subscribe
- Permalink
Experiencing buffering issues since installing AC1200 RBK13-100NAS 3 Piece Dual Band WiFi. Anyone seen this and have a resolution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1200 RBK13 Mesh Router Buffering when streaming Netflix and Amazon Prime
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
