Orbi WiFi 7 RBE973
Reply
ADT Cloud link not working with Orbi
robbiethomas
Follower
When I connect my ADT home security cloud link to the orbi Wifi router using the Ethernet wire it does not work. When I connect the ADT cloud link directly to my Arris Modem using the Ethernet wire it works. The ADT technician said that it was a problem with my Orbi and I could not connect ADT or Arlo cameras to the Orbi router. Is this true? How do I fix this? Should I purchase a new modem or router?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: ADT Cloud link not working with Orbi
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1204 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
