Reply
AT&T hot spot connection
TIJ
Follower
Follower
Can the Orbi system be connected to my AT&T Hot Spot?  Via wifi?
Message 1 of 3
Guru
Re: AT&T hot spot connection
https://community.netgear.com/t5/Orbi/AT-amp-T-hot-spot-connection/td-p/1736299/jump-to/first-unread...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW)/RBK853 AP Mode v3.2.18.1
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Duplicated here:
Solved: AT&T hot spot connection - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 647 views
  • 0 kudos
  • 3 in conversation
Announcements
