Orbi WiFi 7 RBE973
Reply
Abode Streaming Video on Orbi
GT2118
Follower
Abode Security Streaming HD Video issue on ORBI WiFi. (Yes, this issue is an open ticket to Abode Support.)
Background: Abode Security allows for user-generated automations (scripts) to run sensor-triggered tasks. I created a very simple script that sends a "record video" command to an Abode Streaming HD Camera when a particular door sensor is tripped. The automation successfully runs every time it is triggered.
Problem: Abode Security IF/THEN automation doesn't consistently capture video thru ORBI WiFi, but does consistently work thru ORBI ethernet port.
Camera connected to Router via ethernet: Video capture works every time script runs.
Camera connected to Router via WiFi: Video capture sporadic when script runs, but video capture works every time camera is addressed directly thru web or app.
Camera connected to Satellite via ethernet: Video capture works most of the time when script runs.
Camera connected to Satellite via WiFi: Video capture sporadic when script runs, but video capture works every time camera is addressed directly thru web or app.
It is interesting that when there is an air gap in the connection (WiFi or mesh) the the script has problems getting the camera to respond, but when the camera is connected directly to the router (no air gap of any kind), the camera successfully receives and executes the capture command every time.
Any thoughts or suggestions?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Abode Streaming Video on Orbi
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 427 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
