- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Absurdly Low Internet Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
We pay for 40 mb/s down from Centurylink, and recently have been receiving extremely low speeds (Under 1 mb/s down, lower than 0.5 mb/s up). The speedtest built in the router login reports 30-35 down and 2-5 up speeds, while any device (including ethernet and wireless connected) show the ubsurdly low speeds mentioned before. I have already made sure firmware is updated, used automatic IP and Cloudfares services for IP, but to no avail. No devices are heavily using the internet, and I have never had this problem before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Absurdly Low Internet Speeds
Is the Orbi system operating in Router or AP mode?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
