Reply
Ac2200 setup
GeorgeWhitehead
Follower
Ac2200 setup
I check devices connected and shows total of 3, but I only added 2.  The third one is unknown. Does the Orbi wall Plug Satellite show up as the third connection?
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 2
Guru
Re: Ac2200 setup
What FW is currently loaded?
What browser are you using? Try different browsers like IE11, FF or Opera to see any differences.
What is the model# of the walll plug?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 358 views
  • 0 kudos
  • 2 in conversation
Announcements
