Reply
Access Control and Amazon FireTV
MarkXIX
Believe this issue to be a bug with the router.
I have multiple Amazon FireTV sticks on my network. One particular device will draw an IP address but will not connect to the Internet as long as I have "Turn on Access Control" enabled in the Access Control management page.
This one device is the only one impacted by this setting being enabled. Have contacted Amazon support and they have been able to remotely diagnose the device and cannot find an issue with it.
It does not matter if the device is on 2.4G or 5G network. I have tried both normal DHCP IP assignment and creating an IP reservation. The device MAC in unique on my network as well and I have verified there are no IP address conflicts.
The only way to get this ONE DEVICE to connect to the Internet is to uncheck the "Turn on Access Control" option in the router settings.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System, RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 6
Mikey94025
Prodigy
Re: Access Control and Amazon FireTV
How odd.  I have Security...Access Control turned off (I've never tried to enable it) with 2 Amazon Fire TV devices that work just fine.
Message 2 of 6
Guru
Does this happend with the one device if ALL other Amazon devices are turned off or disabled?
Faulty device maybe?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 3 of 6
MarkXIX
If you're so inclined, try enabling Access Control and see if any of your FireTV devices stop working.
If not, I appreciate the response.
Message 4 of 6
MarkXIX
I will try unplugging the other two FireTV devices and see what happens to the one that's having issues as an additional troubleshooting step.
Message 5 of 6
Guru
Let us know the results.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2255 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
