Reply
Access Control randomly blocking device after power outage
feignit
Star
This is the second time this has happened to me, after a power loss from a blackout etc, my Orbi randomly blocks devices from internet access. Last time I was able to view these blocked devices and resolve it while still keeping access control enabled, but now the blocked device list is blank. I can only connect these devices after completely disabling access control. It's much like the issue mentioned here: https://community.netgear.com/t5/Orbi/Access-Control-randomly-blocking-approved-devices-on-V2-2-1-21...
This is completely ridiculous, I'm tired of this buggy mesh system. I reached out to customer service and all I got was generic replies. Firmware 2.5.2.4
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Mstrbig
Master
Re: Access Control randomly blocking device after power outage
They may mean that you are on 2.5.2.4 and it's buggy? The firmware showing on the website is 2.5.1.16 and seems to be very stable.
I don't use access control or other features like that for obvious reasons, so I can't help youy there. But falling back to 2.5.1.16 may solve the problem.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 2 of 4
feignit
Star
I’ll have to give that a try
Message 3 of 4
Guru
Try a factory reset on the RBR after you loaded v4 FW. Then setup from scratch.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 596 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
