- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Add new nodes and compatibility
- Mark as New
- Bookmark
- Subscribe
- Permalink
with the wifi AC3000 what other nodes can be added to it? can one mix-match other modules
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Add new nodes and compatibility
Yes, with the AC3000 (RBR50, which has 4x4 backhaul antennas supporting up to 1.7 Gbps) you can basically connect any other Satellite type:
- If you add an AC2200 Satellite (RBS20, RBS40, RBS40V or RBW30) you will limit your backhaul between the Router and that Satellite to 2x2 (867 Mbps).
- If you add an AC3000 Satellite (RBS50 or RBS50Y) then you will get the full 4x4 (1.7 Gbps) backhaul
All of the above Satellite types will give you 2x2 fronthaul antennas supporting up to 866 Mbps (5Ghz) + 400 Mbps (2.4GHz)
Please see this for more information: https://kb.netgear.com/000038220/Which-Orbi-WiFi-System-is-best-for-me
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can not add RBR## units to other systems as extenders.
