Discussion stats
  • 1 reply
  • 514 views
  • 1 kudo
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Add-on Orbi Outdoor Satellite (RBS50Y) Compatible with RBK53
Hello everyone,
Somebody happens to know if the Add-on Orbi Outdoor Satellite (RBS50Y) is Compatible with RBK53 AC3000, i was looking in the datasheet and it seems that the answer its no, just want to make sure before buying them. thanks in advance
Message 1 of 2
Accepted Solutions
Highlighted
Guru
Re: Add-on Orbi Outdoor Satellite (RBS50Y) Compatible with RBK53
Yes, The RBSY requires a Orbi system like the RBK53.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
All Replies
Highlighted
Guru
Message 2 of 2
