- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Adding a satellite unit
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I add a RBS20 — Orbi AC2200 Tri-band WiFi Add-on Satellite, will my wired connection be faster?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Adding a satellite unit
The RBS20 is rated at 866Mbps connection rate with wireless devices. Most wired LAN connections now days are rated at 1000Mbps. LAN ports in back of RBR and RBSs are rated at 1000Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying to speed my streaming connection.
So the satellite wired connections on the back will have up to 1000Mbps connection through the wireless connection from the main Router (RBR 50)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, the connection rate between the RBS20 and the RBR50 wirelessly will be 866Mbps. You can wire LAN connect the RBS to the RBR, then the rate will be 1000Mbps between the two: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Distance is less than 30 feet, but wireless hates my house. I'll review your suggestions with my work IT consultant as I'm not a technician. Honestly, I don't speak the language.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Depending upon building materials, these can effect any WiFi signals, especially concrete and steel. If wood and sheet rock, i would make sure distances are starting at 30 feet between RBS and RBR. Too close and signals cause too much signal over lap and can cause problems. Placement and distance is key.
