Orbi WiFi 7 RBE973
Reply
Adding additional Satellites
Arowana
Follower
I have setup a Orbi AC3000  with the three units,  One router, and two satellites.
I would like to add three additional satellites.
Is it possible to purchase the same three unit set and use them all as satellites to save a few hundred dollars?
If I purchase three satellites it seems like it would be much more as i cannot find them in packs of three.
Thank you
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Re: Adding additional Satellites
hi
no you cant use the orbi router in the 3 pack as a sat
why would you need so many sat's , the 3 pack you purchased covers a huge area and if you had more sat's you would need even more area to put them in as too many says in to close a proximity just over saturates the wifi and makes it all go to crap
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1052 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
