Orbi WiFi 7 RBE973
Reply
Additional Satellite for RBK53S Orbi Mesh System
Easypickins
I currently have an ORBI RBK53S Mesh network with 1 Router and 2 Satellites.
I want to purchase ONE additional satellite to extend my networks range.   What is the best ORBI extender to purchase for this system?   I do not want any compatability problems.
Thank you.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 9
DeanB1452
Apprentice
Re: Additional Satellite for RBK53S Orbi Mesh System
You can add another RBS50 to extend the range.  I have the same system and added a RBS20 and have the whole house and backyard covered on a 6100 sq ft corner lot.
Message 2 of 9
Guru
RBS40v, RBS50 work. Also EX7500, 7700 or 8000 can work as alternatives.
Thank you.
Message 3 of 9
Easypickins
Where can I find the item you recommended with just the Satellite unit?   All the systems I find online have the Router and the Satellite.  I do not need another router.  Just the satellite extension.
Message 4 of 9
Easypickins
Where can I find the items you recommended with just the Satellite unit?   All the systems I find online have the Router and the Satellite.  I do not need another router.  Just the satellite extension.
Message 5 of 9
vajim
Master
have you tried amazon or best buy, or walmart?
Message 6 of 9
Easypickins
Yes but I cannot find a product that is JUST the satellite unit.  They all have the Router and the Satellite.
Message 7 of 9
DeanB1452
Apprentice
EBay has several.  Some from eBay shops that have a return guarantee if not satisfied within 30 days.  I purchased my RBS20 from eBay.
Message 8 of 9
vajim
Master
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1272 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
