Orbi WiFi 7 RBE973
Reply
After Orbi factory reset, Disney Circle app "Can't connect to Circle"
monroema
Follower
After Orbi factory reset, Disney Circle app "Can't connect to Circle".  Unfortunatley I did not backup Circle settings prior to Orbi factory reset.  I have attempted to turn Circle off on Orbi, reboot and then re-enable Circle.
When I view a profile in the Android app I see a message at the bottom which stated "Not connected to Circle!" with a button to RECONNECT.  When I click that button is show "connecting...".  Then there appears a "Connections" button on the bottom.  When I click that button I get the message  "Can't connect to Circle".
Any insights or suggestions would be appreciated.
Thanks!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Guru
Re: After Orbi factory reset, Disney Circle app "Can't connect to Circle"
You might contact Circle support and ask for additional help with this:
https://www.netgear.com/support/product/circle.aspx
Message 2 of 3
ekhalil
Master
Thanks!
That's the way Circle works! Every time you do a factory reset for Orbi you will need to reconfigure Circle from scratch. It seems that there is a certain Circle "ID" in Orbi that is cleared when you do a factory reset.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1826 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
