Orbi WiFi 7 RBE973
Reply
After firmware update unable to locate AC2200 rbr20 2.4 band
Wan21
Follower
Our Switch is connected to it but other than that you can not see it on any other devices to be able to connect to it
Message 1 of 2
Guru
Re: After firmware update unable to locate AC2200 rbr20 2.4 band
the RBR20 uses bandsteer and single ssid function. Meaning it uses the same ssid for 5ghz as it does for 2.4ghz.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 233 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
