- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AirPrint/BonJour devices not discoverable when connected to Guest Network (ORBI RBK50/RBR50 system)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AirPrint/BonJour devices not discoverable when connected to Guest Network (ORBI RBK50/RBR50 syst
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not only that, but when a printer is connected to the Guest network, the normal "guest" settings will not allow any device to print to it.
The Guest network (on the web interface) clearly shows option:
Allow guests to see each other and access my local network
Unless this box is checked, devices on the Guest network (a) cannot see each other (i.e. the printer), and (b) cannot access the primary network.
I agree that there are a lot of other ways Netgear could have set up the Guest network, such as (a) all the Guests can see every device on the Guest network, and (b) devices on the primary network can open a connection to devices on the Guest network. But, those may be a lot harder to program. Anyway, they did what they did.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fair enough. I should have logged into the web interface and poked around. (I honestly didn't know it existed, but again bad on me because most do).
However, they should update the firmware to allow guests to see each other but *NOT* into the main network. That's the main point of the guest network. I don't want guest clients bleeding into my main network and have knowlegdge or access to any main network devices. The code can't be that difficult to implement. The devices are all on the same subnet between guest and main networks, so they're doing something to limit visibility with each other already. The router knows which devices are connected to the guest network. Doesn't seem like it's much of an extension at that point. Netgear, what do you think?? Get me an update!
- Mark as New
- Bookmark
- Subscribe
- Permalink
