Reply
Airplay & Orbi Mesh Network
dwayneycl
Device
Orbi RBR40*1 / Orbi RBS40*1 / Orbi RBS50*1
My hompod(or any airplay device) is connected to RBS50, but my phone is connected to RBS40 showing that my phone cant not airplay to hompod, is there any that I can do?
Message 1 of 5
Guru
Re: Airplay & Orbi Mesh Network
What happens if you turn OFF The RBS50 and let the devices connect to the rest of the system...?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 5
dwayneycl
It's work but my tv will have no connection then.
Message 3 of 5
Mstrbig
Master
@dwayneycl wrote:
Device
Can you describe how you have your Satellites set up? If your phone is on the same subnet as your hompod, you should not be having this issues. Your satellites will all be on the same subnet as the router. So anything connected wired or wirelessly, will be pulling its IP address from the DHCP. Ping the IP address of the hompod and post your results.
I would check your network settings and WIFI settings on the phone and compare them to the hompod.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 4 of 5
mith_it
Luminary
I use AirPlay no problem. Sounds like something is wrong in the satellites setup
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 662 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
