- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Alarm Control Unit - Setting up Wi-Fi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an alarm panel that reuires the WI-FI to be setup using a smartphone. The Alarm Control Unit is 2.4 Ghz only. For the setup to work they must be on the same network. I am assuming the connection is not working because my phone is connecting to 5 Ghz. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Alarm Control Unit - Setting up Wi-Fi
Devices connecting to 2.4G and 5G are both on the same network and can communicate with no issues.
It's more likely that your alarm system control unit is not actually connecting to Orbi's WiFi network at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is possible the control unit is not connecting. There are no indications on the control unit what network it is connecting too. I have reached out to the company.
What about the turning off the beaming feature?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't give you a suggestion I know will work. You could try turning off beamforming, or try each setting of the 20/40 MHz coexistence feature under Advanced Wireless Settings, 2.4 GHz.
