- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Am I experiencing firmware issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I signed on this morning to find Security Certificate errors when opening my browser. I checked my internet connected and found limited connection.
I have a RSR40 and (2) RBS49 satellites. Everything worked great last night.
Now when I check connected devices I find that the satellites are listed as a connected device not as a satellite. All three Orbi products are at V2.1.2.18.
I was running Disney Circle (Orbi) but have since deactivated it.
I can access cameras that are supposedly not connected but cannot access cameras that supposedly are. Some of my Amazon devices have/had internet connectivity; some don't. My laptop had a connection once in the last 5 hours but it didn't last long.
I use a Verison MiFi router that is functioning correctly.
All of my network devices have been rebooted. This have probably gotten worse with each reboot.
So ... is this the firmware problem that I'm reading about on the forum? How do I return to a firmware version that works?
Of course, I've had my Orbi more than 3 months so customer service isn't free.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Am I experiencing firmware issues?
Why are you using the Verison MiFi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use the Verizon MiFi router because Verizon is my ISP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK....I assume it's a requirement. Another example of ISP control mesaures. Reading over the number of folks that have problems 'most' are using the Orbi as a second router.
If there is anyway you can ditch the Verizon router, I would do so and run your connection straight out of their modem. But that's probaly not possible.
Good luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've now turned off the closest satellite forcing my laptop to connect to the Orbi router and have a connection. However, as soon as I turn the satellite back on, I lose my internet connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the Verizon modem have a DMZ by chance? If so, you might try putting the IP address the Orbi router gets into the modems DMZ. Disable ALL wifi radios on the ISPs modem.
@ykcharrierwrote:I signed on this morning to find Security Certificate errors when opening my browser. I checked my internet connected and found limited connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've fixed this now by manualy updating the firmware in the router and both satellites.
Interestingly my son said that the security certificate errors I got this morning are the same he gets when he tries to get on the internet when Circle blocks him. My computer was set as unmonitored.
- Mark as New
- Bookmark
- Subscribe
- Permalink
