Reply
Highlighted
Amazon Cloud Cam not connecting
Hi, until recently, my 3 Amazon Cloud Cameras were working fine and after a power outage and modem/router restart, I can't connect them anymore. All other devices work perfectly. Amazon says my wifi needs to be 2.4 which I can see along the 5.0 when I connect to my router. Any ideas?
Modem: Netgear CM500
Router: Netgear Orbi RBR40
Message 1 of 7
Highlighted
Guru
Re: Amazon Cloud Cam not connecting
What NG router product are you referencing?
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 7
Highlighted
Thanks. I have an Netgear Orbi RBR40 and the modem is a Netgear CM500
Message 3 of 7
Highlighted
Guru
Has the SSID name and PW been changed or have they remained the same?
Have the cameras been powered OFF for 30 seconds then back on to see if they re-connect?
You can try this to see if they can be re-connected to the system:
https://community.netgear.com/t5/Orbi/orbi-20-cannot-connect-Swann-Camera/m-p/1822441/highlight/true...
Message 4 of 7
Highlighted
Sensei
Well, thank goodness this is not a plea to "turn off 5G", because they were working fine before the power outage.
While most electronic devices handle unexpected power loss well, it might be that these cameras somehow did not.  Surely there is a "reset to factory" method.  I would pick the camera that is the easiest to reach, reset, and reconfigure it.
I would also assign specific IP addresses to each camera using the Orbi web interface, Advanced Tab->Setup->LAN Setup.  After a power outage and restart, the cameras could have received different IP addresses than they had before.  "Should this matter?"  No.  "Could this matter?" Who knows?
I love my Orbi.
Message 5 of 7
Highlighted
Thanks, shall I uncheck "Enable SSID broadcast" only for the 2.4?
Message 6 of 7
Highlighted
Guru
5Ghz SSID Broadcast.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 560 views
  • 0 kudos
  • 3 in conversation
Announcements
