Reply
Star
Android devices keep getting thrown off the Orbi WiFi
(This was also an issue before the latest firmware)
Our Android devices (tablets and phones) keep experincing the same issue. They are all sporadically thrown off WiFi and re-connected again a few seconds later.
What could the reason for this, and any recommended way of fixing this issue? I've done no changes to the basic Orbi setup, other then enabling Ipv6 and changing the DNS (issue was also present before doing those two changes).
I previously had a Nightahwk X8 where this never was an issue, so I'm worried either a setting or the Orbi system itself is flawed. In general I feel like the X8 has been superior in terms of speed, range and stability. Is that supposed to be correct?
Guru
Re: Android devices keep getting thrown off the Orbi WiFi
Wonder if the two are related?
https://community.netgear.com/t5/Orbi/iOS-devices/td-p/1189718
Morse is faster than texting!
Star
Looking at the thread at a glance, I don't think so. I've never had issues with the iOS devices in the house and this was before the latest firmware hit, it's also present on the latest firmware. But the root of the issue might be the same.
Guide
I have the same problem with two android phones. My IOS products work fine but the android ones keep ketting disconnected en reconnected. Very very annoying. I am honestly thinking about returning this product because its faulty in my opinion.
Yes same issue here.
Android client (Samsung Galaxy) disconnects and then reconnects - it reconnects quickly but is frustrating
NETGEAR Moderator
Hello everyone
First thing I would try to do is to disable beamforming and Mu Mimo see if that is causing the issue. The setting is located in Advanced-Advanced Setup- Wireless setting and should be 2 check boxes at the bottom. The other thing I can think of is the wifi radio may be bouncing back and forth between the satellite and the main router causing the disconnects you could try to position the satellite a little further away if possible.
DarrenM
Guide
Those options are off and Intried every channel available. No luck. Its really an issue with android and this router. I will bring it back after the holidays.
Guide
And the router and sattelite are two floors apart. The next would have been to put the sattelite on the roof and I guess thats not the idea. Its just not as greatbas I expected from the ads. I had a apple network (much slower) but that was stable.
The Android device is normally connected to the main router (not satellite) when disconnects occur.
Placement is per recommendations - router where Intenet (cable modem) accesses the house and satellite in center of the house. Disconnects occur when devices  are closer to the router (and connected to the router).
Virtuoso
I am running an S7 Edge and a Galaxy Tab S2 with no problems on a new Orbi installation (about a week old).
Happy to run some tests for you if that will help.
Star
Did you change anything to settings within the router?
Are you using a ISP modem/router and connecting that to the Orbi?
Trying to wrap my head around why so many of my devices can't keep a stable connection to the system.
Virtuoso
I have the Orbi plugged directly into my AT&T residential gateway.
I made no changes to the Orbi settings.
We have Iphone's, wireless printer, Roku, wireless thermostats, Kindle and the android devices all working well with the Orbi.
During installation Orbi assigned 10.0 IP range to the  to keep it separate to the 192.168 range of the AT&T RG.
Prior to the Orbi I had another Netgear router also attached to the RG and also manually changed the IP range to 10.0. Before making this change I had connectivity issues.
Maybe try and do a reset on the Orbi as a long shot? Also maybe restart the router that the Orbi is attached to.
Check the IP ranges of the Orbi and your router.
Apprentice
My android devices and Sony Xperia z4 tablet and phones also experience random WiFi drops frequently, have tried factory resets many times, different channels disabled beamforming nothing works this issue was a lot less frequent on old 16 Firmware with the 18 Firmware it happens constantly
Tutor
I ran into the same issue holding a connection for a Samsung Galaxy Tab 3. I opened the orbilogin.com site on my desktop when I tried to connect the tab3 and noticed that the ip addresses did not match. The orbi assigned 192.168.1.5 but the tab noted the address of 192.168.1.125. I went into the tab3 advanced setup under the orbi connection and changed the dhcp setting to manual and entered the 192.168.1.5 with the other settings left alone.
Once I restarted the tab it connected quickly and so far seems to be working. I know its not the perfect solution, but it'll work while you're in your home.
Good luck.
Retired_Member
My S7 Edge is constanly about every 5 seconds losing the wifi then it connects again.
Virtuoso
[ Edited ]
This is really odd.
I am also running the latest firmware V1.4.0.18  (updated the satellite first and then the base) and both of my Android devices (S7 Edge and Galaxy Tab S2) have no issues.
Do you still have wifi enabled on the router to which the Orbi is attached?  Have you tried linking your devices to that wifi?
What is the IP address range of the existing router and is it different from the IP address range of the Orbi?
As mentioned before, the IP address range of devices attached to my AT&T gateway are in the range 192.168 and the Orbi 10.0.
After attaching the Orbi to my AT&T gateway I then restarted the gateway, Orbi then automatically assigned the 10.0 range to the Orbi.
Retired_Member
[ Edited ]
https://youtu.be/eIR66mBkJD8
My Orbi is my router.  No other wifi in my house.  Here is a video of my android phone s7 Edge doing what I am saying.  Watch the wifi signal and you will see 4G LTE popping up every 5 sec.
Virtuoso
Who is your ISP and how do they get the signal into your home?
Have you tried a direct connection to the Orbi using an Ethernet cable from a computer just to see if the wifi is dropping or the incoming signal?
Have you tried downgrading to V1.4.0.16?
Retired_Member
Suddenlink.  Through Cable. That is how my PC is directly connected to the ORBI.  No, I haven't downgraded as I had the same issue on 16 before I upgraded.
Virtuoso
OK got it.
What is the model number of the Suddenlik modem?
Have you tried running wifi analyzer, you can download it from the app store. It will give you a visual picture of what wifi signals are transmitting in your area and on what channels.
This to make sure that there are no signals that could be interfering.
By default the Orbi sets it's 2.4Ghz channel to Auto and the 5Ghz channel to 48.
Let's see if we can get to the bottom of this.
Retired_Member
I've actually used wifi analyzer and we do have other signals. The bands I'm using are ones that have the least interference from others actually.
The modem really has nothing to do with the issues here. It's an Arris cm820. I've set the 2.4 to 9 and since I only had I believe 3 or 4 channels to select from on the 5ghz I left it at 48.
Virtuoso
Try and set the secuirty option on Orbi to none and do a quick test.
In some instances WPA2-PSK [AES] have been known to cause problems, a long shot but give it a try.
Initiate
Has this issue been solved? Im having the same problem with my samsung galaxy s6.. I get dropped out from the wifi connection and then it reconnects right away...
Retired_Member
After Netgear support had me turn off Beamforming and back on, it seemed to resolve my issue.
Initiate
I'll try that later when I get home from work.
Thanks for the tip..
Discussion Stats
Top Contributors
