- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Another RBR50 Dropping Internet Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Another RBR50 Dropping Internet Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
This thread is huge. Which suggestions worked for you because I'm about to Office Space mine...
@TheGarbageMan wrote:"I made the changes, and sure enough.... been up for a week without incident."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if this helps:
@TimmyTechTV wrote:This thread is huge. Which suggestions worked for you because I'm about to Office Space mine...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to telnet into your router and fix the Ip lease time.
Just follow the directions. It’s not super complicated. If you’re running Windows 10 you may need to enable telnet first. It’s built into windows but not enabled by default. You can google how to turn it on.
Been up for weeks now without incident.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This worked for me as well for my TLC Roku TV that kept dropping internet connections everytime it was turned off and never auto reconnected to network. I have a Google Fiber router with this Mesh router setup setup. Seems like this should be the default setting now with some patch - config set wan_lease=1200. This solution is way to technical for most users IMO.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you already have a router in front of the Orbi router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Your configuration would impact now Orbi works, even with out making the change reported here.
@meisert wrote:This worked for me as well for my TLC Roku TV that kept dropping internet connections everytime it was turned off and never auto reconnected to network. I have a Google Fiber router with this Mesh router setup setup. Seems like this should be the default setting now with some patch - config set wan_lease=1200. This solution is way to technical for most users IMO.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Been having a similar issue with my new RBK753 and have been trying to follow the directions here, but whenever I go to the Debug page, there's no option to enable Telnet. Has the ability been removed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post about this over in the Orbi AX forum for your model Orbi:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Telent doesn't seem to be a feature on Orbi AX.
Thank you.
@RockTheGlobe wrote:Been having a similar issue with my new RBK753 and have been trying to follow the directions here, but whenever I go to the Debug page, there's no option to enable Telnet. Has the ability been removed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi There,
I also came across the same problem after receiving a new cable modem.
I did the following to resolve the problem.
On my cable modem:
I put off all the wifi signal sending.
I put a static ipadres in it for the orbi modem.
I put the dmz mode with the ipadres of the orbi.
I connected the Orbi direct to the cable modem.
On the Orbi:
I put the orbi in AP mode.
Turned on 20/40 mhz
Turned on WMM(2.4 and 5Ghz)
Preample automatic on both with 100% signal strength
Turned off Backhaul
Turned on beamforming
Turned on MU-MIMO
Turned off Fast Roaming
2.4 Ghz channel: automatic
5 Ghz channel is on 40(I did some tests on every channel and for me this was the fastest)
Guest network is off
No dynamic DNS
My Orbi is running at version 2.5.1.16
Make sure the Satellites ar on the same version!
I have 2 indoor satellites and one outdoor satellite.
After this setup I didnt had any drops that where common in the weeks before.
Hope this will help
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend NOT using the modem DMZ for the RBR in AP Mode. When in AP mode, the RBR doesn't provide any kind of firewall protection. This is only used when the RBR is in router mode. IF you have the RBR in AP mode in the modems DMZ, you maybe suseptible to attacks and are NOT protected by the modems firewall.
@DsxUndertaker wrote:Hi There,
On my cable modem:
On the Orbi:
Turned on 20/40 mhz
Turned off Backhaul
Turned on MU-MIMO
No dynamic DNS
Hope this will help
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the Ip adres filled in but disabled the option. Orbi still works fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, just checking.
- « Previous
- 1
- 2
- Next »
