Reply
Highlighted
Any plans to reconcile the client Device types between Orbi web interface and Orbi App?
Not the most important feature in the grand scheme of things I suppose but some client device types listed in the iOS App are not available in the Orbi web interface and as a result, any changes made in the app are not permanent.  One example is editing the client and selecting AV Receiver for client type in the app.  The web interface does not have this type so of course the change will not be permanent in the App.  I'm not sure how many differences exist between the two but this is one of them.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 5
Highlighted
Guru
Re: Any plans to reconcile the client Device types between Orbi web interface and Orbi App?
@DarrenM
@Christian_R
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 5
Highlighted
NETGEAR Moderator
Hi @papachungo13
This is a great suggestion for this feature to be added to the Orbi web interface as you will want to post this over in the idea exchange.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Christian
Message 3 of 5
Highlighted
Thanks @FURRYe38 and @Christian_R
I posted it as suggested
Message 4 of 5
Highlighted
Guru
Good Luck.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1186 views
  • 2 kudos
  • 3 in conversation
Announcements
