Orbi WiFi 7 RBE973
Reply
Ap mode which network to conmect to
Txko
So I put my orbi in ap mode. Now I have a choice between frontier 2.4GHz frontier 5GHz and "wolf" frontier is my ISP networks and wolf is the network I named with orbi. Which network do I connect to?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 12
vajim
Master
Re: Ap mode which network to conmect to
or maybe put the frontier device in ap mode and use the orbi as 'the' router
Message 2 of 12
Txko
So if I connect to the frontier network will the orbi which is placed in ap mode be actively boosting the signal of that network???
Message 3 of 12
CrimpOn
Guru
Short answer: "it depends".
If all you want is for devices to use the interent, then it makes no difference which WiFi they connect to.  If you begin to install Internet of Things (IoT) devices, such as smart plugs, smart speakers, video doorbells, etc. then the smartphone that is being used to set them may have to be connected to the same WiFi network during the setup.
There was probably a reason for purchasing the Orbi, such as the Frontier WiFi not covering the entire house?
If you want mobile devices (phones, tablet, laptops) to remain connected as they move around the house, then using the Orbi WiFi will make for a better experience because it should have wider coverage.
Most customers would choose not to have two WiFi radios competing with each other inside one house. (Bad enough that neighbor WiFi radios radiate into the house!)  So, most customers would turn off the Frontier WiFi.  (There may even be a button on the unit to do so.)
There was probably also a reason why the Orbi was put into AP mode?
Message 4 of 12
Txko
I put the orbi in ap mode because I was getting faster speeds via frontier network then orbi. I figured at the very least orbi would expand my coverage. However from reading your post it seems that by connecting to the frontier network I'm not actually receiving any benefit from the orbi correct?
Message 5 of 12
vajim
Master
do you need the frontier device?
if not get rid of it.  the orbi is fully capable of providing you all the internet you can handle
Message 6 of 12
CrimpOn
Guru
You are correct.  If you never connect to the Orbi (wired or WiFi) then it does nothing for you.
As @vajim pointed out, if you do not need the Frontier device, you can consider taking it out.
In my experience, most ISP devices that offer WiFi are combination modem/router/WiFi units
You MUST have a modem.  Orbi does not include the modem.
What I diid was have Spectrum replace my combination device with a "modem only" device.
Message 7 of 12
vajim
Master
I'm still amazed at the number of folks who buy an Orbi and try to run it with another router.  If their ISP requires that (Verizon comes to mind) then that's different. But to think another router is going to allow you to send wifi to the moon is ludicrous.  If the thought is looking for extra ethernet connections, wouldn't a simple switch provide the same functionalty?  The other part to this is the number of people who buy the Orbi (without doing homework) not realizing that 2 routers in a system requires special configuation and an open inviation to problems.  Yeah. I know it can be done, but for the casual user this type of setup may beyond what they bargained for.  BUT, on the other side that's what this forum is for to unscrew NAT stuff amongst other poop.
Message 8 of 12
Txko
So would the correct move be to keep the frontier device as the modem, and disable the wifi on it?
Message 9 of 12
Txko
This is a picture of my router/modem that was provided via Frontier
Message 10 of 12
Txko
Also I have tried to name both bands unique names but after about 5 minutes the 5ghz mirrors the 2.4 and become one. There has to be a way to uniquely name both bands correct?
Message 11 of 12
CrimpOn
Guru
No. There are a number of (very long) posts on this topic.  People have pleaded with Netgear for years without success.  Some very clever people have found ways to "hack" the Orbi firmware to give different SSID's to the 2.4G and 5G bands.  Netgear does not support this effort.  Those who do it are "on their own."  If a new firmware release breaks their "hack", they must either give up the practice or remain on whatever firmware they got to work.  My own (personal) opinion is if different SSID's for 2.4G and 5G bands are absolutely critical, "can't live without it" needs, then buy something besides an Orbi.
Frontier WiFi obviously follows the traditional methodology which gives the 2.4G and 5G bands different names, with one of them adding "5G" at the end.
I can understand you are in an awkward spot.  You have carefully selected which band each device would connect to by SSID.  Switching to one SSID means that (some number) of devices have to be reconfigured.  That is tedious.  I (again personally) might look on this as an opportunity to move away from having my WiFi called "Something 2G" and "Something 5G" (Is it actually "frontier"?) and pick an SSID I like better.  "Wolf" sounds good.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 897 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
