- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Apple Expresses keep dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
My home wifi system has been spiraling out of control... it was working alright with my ASUS router but I didn't have enough range so I picked up the Orbi System (base with one satelitte).
I have faster speed and better coverage throughout the house when using my laptop and phones... but all my streaming devices aren't happy. My airport expresses (which I use for streaming music) are dropping left and right.
Installed all the updates but still no luck.
Any help/insight would be much appreciated.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Apple Expresses keep dropping
Not sure how you have things setup, but you do not want more than one device broadcasting WiFi. That will cause problems. Turn off the WiFi radios in your Airport Express units and connect them to your network using Ethernet. Orbi should be the only SSID available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All the airport expresses are set to join an existing network, so I don't believe that is the issue.
My expresses are too far to hardwire (via ethernet)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try disabling MIMO, Daisy Chain and Fast Roaming.
Try manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It might not be convenient, but a wired setup would be better. You can connect the Airport via wire to the Orbi router or to any Orbi satellie, and you can use a long cord, so you should have some flexibility in where you place things.
In any case, you should try the Airports in a wired setup and see if that resolves your issue. Then you can go from there.
See the instructions in this article. Are the Airport devices set to bridge mode, as described in the article?
http://www.theinstructional.com/guides/configure-an-airport-express-as-an-ethernet-airplay-receiver
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry... but that's just silly. The airport expresses have worked wirelessly for years with other routers. This problem is strictly related to the introduction of the Orbi system and I will replace the Orbi's with a mesh system that functions how I want it before running wire thoughtout my house.
