Orbi WiFi 7 RBE973
Reply
Apple TV not connecting to Orbie
Crg1
Star
My Apple TV is unable to connect to new Orbie RBR50. Connected fine to WRT1900 yesterday. Is this a problem with the Orbie or is there a setting in the app to allow the Apple TV in? Not allowing Apple to connect is a BIG problem. May need to return Orbie.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Apple TV not connecting to Orbie
Hello Crg1
Can you give more detail on what the Apple TV is doing when trying to connect to the network?
DarrenM
Message 2 of 4
Bajen
I guess IT has to do with Portsmouth that Apple has to use. Then I did som portforwarding IT worked for Me 😁 Appletv nejds to have Access to certain ports for activation and so on
Look at: https://support.apple.com/en-us/HT202944 for portnumbers.
Message 3 of 4
Crg1
Star
Actually I just rebooted the Orbie and I was able to connect.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2284 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
