Orbi WiFi 7 RBE973
Reply
Are these RBR50 settings appropriate
flroots
Guide
I've recently purchased the RBK50. I read that these settings provide optimum signal strength and speed. Can anyone verify?
Ref: https://averagetechblog.com/how-to/netgear-orbi-settings/
- Daisy Chain Topology: Disabled (unless you have 3 or more satellites)
- MU-MIMO: Enabled
- Implicit Beam-forming: Enabled
- Fast Roaming: Disabled
- UPnP: Enabled
- WMM (WiFi Multimedia): Enabled
- Enable 20/40Mhz Coexistence: Enabled
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Are these RBR50 settings appropriate
Yes.
You can set 40Mhz Coexistence only. Uncheck the check box then apply.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 300 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
