Reply
Attached devices in the web ui and in the app appear to be incorrect
Spanky2k
Initiate
I set up my new RBK53 and after some teething issues with one of the satellites and some forced firmware updates, everything seems to be going well. One thing I've noticed though is that in the Web UI and in the iPhone app, the attached devices don't seem to display correctly. Firstly, most of them say "Wired" even though they have to be connected through WiFi - my iPhone, iPad and my Nest Thermostats, for example, all say they have a "Wired" connection. Secondly, all but 1 of 21 devices says it is connected to my main Orbi device. My wife's laptop says it's connected to one of the satellites but even my wife's iPhone (which *does* say it has a "5G" connection unlike my phone) says it is connected to my main Orbi device when it is right at the other side of the house from here and a couple of meters away from a satellite.
My two satellites are connected through Ethernet backbone connections to my main Orbi device, in case that makes a difference.
Performance wise, I don't think for a instant that this will make a blind bit of difference, it just strikes me as odd and I wouldn't mind knowing which devices connect to which device, for interest's sake mainly. Could be useful though if I decide to move a satellite to improve coverage when we redecorate our top floor.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 5
RedBatman89
Guide
Re: Attached devices in the web ui and in the app appear to be incorrect
Yeah this issue is common now with the latest firmware. Enable Daisy chain to see if that fixes it for a bit. New firmware has quite a bit of bugs in it.
Model: RBK22| Orbi AC2200 Tri-band WiFi System,RBK30| Orbi AC2200 WiFi System
Message 2 of 5
Guru
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 3 of 5
ekhalil
Master
Do you have any wired devices connected by LAN cables to any of the Satellites?
The following is my observation regarding "wired" iPhones:
I noticed this morning that my log is full of these DHCP messages:
[DHCP IP: 192.168.1.24] to MAC address 8c:8e:f2:13:bd:87, Thursday, October 11, 2018 07:16:22
[DHCP IP: 192.168.1.25] to MAC address 48:4b:aa:2d:52:5d, Thursday, October 11, 2018 07:16:21
[DHCP IP: 192.168.1.24] to MAC address 8c:8e:f2:13:bd:87, Thursday, October 11, 2018 07:16:20
[DHCP IP: 192.168.1.25] to MAC address 48:4b:aa:2d:52:5d, Thursday, October 11, 2018 07:16:18
[DHCP IP: 192.168.1.24] to MAC address 8c:8e:f2:13:bd:87, Thursday, October 11, 2018 07:16:11
[DHCP IP: 192.168.1.25] to MAC address 48:4b:aa:2d:52:5d, Thursday, October 11, 2018 07:16:10
.... and continues for ever!
- Those two IP addresses are for 2 iPhones, when I checked the "Attached Devices" I saw that only those 2 iPhones were listed as "Wired". All other devices looked ok
- The DHCP messages continued to show in the log even if I switch off the phones
- The DHCP messages only stopped when I disconnected the switch which is connected to the Satellite LAN port. To that switch I have a number of devices connected (3 speakers, Apple TV, Dreambox, Samsung Blu Ray, Wii).
- When the DHCP messages stopped, at the same time the iPhones started to show up as "5G" in the "Attached Devices" list.
Do you see similar behavior?
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 4 of 5
ekhalil
Master
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1098 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
