Orbi WiFi 7 RBE973
Reply
Auto Update Firmware?
cdanthony
Hi,
i just installed my Orbi router 24hrs ago. So far, so good. I was checking the firmware versions. My RBI is currently running 1.4.0.34. I noticed there is a much newer version out. Everything I've read says it auto updates if it's got a firmware version newer than 1.2. Mine has not auto updated at this point. Do I have to do this manually through the orbi login? I'm fairly tech savvy but for some reason, I've always cringed at touching anything to do with router/network setup. I did search the posts but didn't really find the answer to my question.
thanks in advance and hello Orbi Community!
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
vtrusty
Star
Re: Auto Update Firmware?
for what it's worth i first manually updated the firmware on both my router and satellite. ever since then it has been auto-updating (unfortunately) just fine.
go ahead and just download and update the firmware yourself
Message 2 of 3
cdanthony
So...bad experience with firmware updates...not just the newest 1.12 update?
thanks for your response
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2044 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
