- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Auto firmware update resets router to factory default settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The past two firmware updates have reset my router to factory defaults requiring me to reconfigure the router to my settings. All wireless devices are disconnected until I can complete this. The recent firmware update/factory reset left me unable to connect to wireless cameras and lighting systems while traveling. Not cool.
Is there a way to disable the auto firmware updates? I've wised up and now have a backup of my settings to restore when the next firmware update happens. Current installed firmware version is V2.3.1.44.
I have contacted support twice now. They have stopped responding to my requests on what recommendations they may have for my issue or if I can disable auto-updates. This is my first Netgear/Orbi system, and I really want to see this setup work out...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Auto firmware update resets router to factory default settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would do a manual load of the FW files on the RBR. Then factory reset and setup from scratch. Be sure to save off a backup configuration to file as well.
Try the 30-30-30 reset as well before re-loading the FW file. Let us know if this helps. Others reported this fixed this on the 20 series Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a 30:30:30 reset this moring. Noiw I'll wait for the next firmware update...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you save a back up configuration to file?
Does the configuration persist thru a reboot or if you pull the power cable from the RBR and plug it back in?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes on the backup of the configuration prior to the 303030 reset. I did a backup after the second time the firware update took the router back to factory default settings. I can power off and back on the router and my saved config loads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Glad it's working now.
Enjoy.
