Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Available channels in 5GHz band
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-09-28
09:01 AM
2018-09-28
09:01 AM
It's a big limitation that the system only allows channels 36, 40, 44 and 48 in the 5GHz band.
There are many other channels in this band that should be possible to use.
Understood that the band is also shared with backhaul connectivity, but the system should be smart enough to select the most suitable channels depending on the surrounding radiations.
Understood also that in most countries those channels should not be manually selected and should follow the DFS and TPC principles but that should be possible to implement in a "smart" system like Orbi. Many low end routers nowadays have such a feature.
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-09-28
09:26 AM
Announcements
