- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BUG: Cannot edit "Internet" VLAN settings (e.g. Priority, VLAN ID)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router Firmware Version
V2.0.0.74
Steps to reproduce:
1) Sign in to orbilogin.com (or whatever method)
2) Click the "Advanced" tab
3) Expand the "Advanced Setup" section in the left list, then scroll down within the list until you see "VLAN/Bridge Settings". Click "VLAN/Bridge Settings".
4) Click "Enable VLAN/Bridge group" and then "By VLAN tag group".
5) Highlight the existing/default "Internet" VLAN tag group and click "EDIT"
6) Change the VLAN ID (e.g. to 201, as I need to do for CenturyLink Fiber internet).
7) Click "APPLY"
Expected results: VLAN tag group page is shown with the new settings specified above.
Actual results: VLAN tag group page is shown with old settings; any changes are not respected/retained/saved. Using the exact steps above, the entire VLAN settings are disabled / not enabled. If you already have VLAN settings enabled, then the "Internet" group will simply remain in VLAN ID 10 -either way, it is uneditable.
Looking for Netgear help here, as this seems to be a bug in their firmware or router settings. Also very interested if others can reproduce, or whether this is just my device.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is now fixed in 2.1.1.12 (See: https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/m-p/1447612#M16893). I was able to set the VLAN ID to 201 on the "Internet" vlan and have removed the century link "modem" from the mix.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BUG: Cannot edit "Internet" VLAN settings (e.g. Priority, VLAN ID)
I have the exact same problem. It would really be nice if Netgear would fix this soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here. Really frustrating because I have to use Centurylink's silly "modem" until this is fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My (hopefully) temporary workaround was to put the Zyxel into Transparent Bridge Mode, which adds the VLAN ID 201 to the ethernet frames. I basically followed this article: https://support.metageek.com/hc/en-us/articles/215467728-How-do-I-use-a-different-router-with-my-DSL..., just transalated the settings into Orbi settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
YES! It works!
I was able to set my VLAN to 101, AP-mode changed to Router-mode and it works perfectly.
Next thing I have to do is to connect an ethernet cable to the satellite, because the connection i "poor". What a great firmwareupdate! 🙂
But the GUI in the VLAN/Bridge settings is pretty non-intuitive. Why do I have to choose between VLAN and Bridge every time I enter the menu?
- Mark as New
- Bookmark
- Subscribe
- Permalink
FWIW: That doesn't happen for me. I did have to first enable it, choose "by vlan tag group" and then click the top "Apply", but whenever I go to the top page I don't have to make any selections.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
FWIW, I had to set & re-set this setting multiple times, and also disconnect & reconnect from my Orbi router - BUT, with persistence, it did finally work. 🙂
