- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BackHaul strength numbers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I followed the instructions per this link
https://community.netgear.com/t5/Orbi/Satellite-5ghz-backhaul-details/td-p/1719529
to enable telnet. My backhaul strength showed -4 but the discussion folks were in -50s, I'm assuming that means I have great signal?
This is relevant copy and paste
"signal strength" : "-4",
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BackHaul strength numbers?
My signal strength is reported as "54" (with quote marks). I, also, had expected a negative number. I do not think that -4 is even possible because of the restriction on WiFi radio signal strength.
Is the satellite working OK?
When you power the satellite off and then back on again, what color is display on the "ring light" for 10 seconds?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
- Mark as New
- Bookmark
- Subscribe
- Permalink
After restarting the satellite the lights flashed blue for a while,than stopped
Then running the commands it still shows
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let's try a different telnet command:
satelliteinfo wifi
Here's my output from the Router:
"mac address" : "A0:04:60:....",
"hop" : "1",
"bridge mac" : "A0:04:60:....",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-67",
"backhaul macaddress" : "A0:04:60:....",
"backhaul phytxrate" : "975",
"backhaul phyrxrate" : "975",
"backhaul parentmac" : "A0:04:60:...."
What "matters" is the backhaul transmission and receive rates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the output for that command
"mac address" : "38...",
"hop" : "1",
"bridge mac" : "38...",
"backhaul rssi" : "-64",
"backhaul macaddress" : "3E...",
"backhaul phytxrate" : "1040",
"backhaul parentmac" : "38..."
Looks like its got the 5 ghz connection rate. The problem I'm trying to solve is satellite placement. My wife isn't keen on the location where I believe it's optimal so I need to be able to move it around and test.
The numbers look similar to what you have
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those number look pretty good to me. It will probably perform well even farther from the router (as far as backhaul speed is concerned).
At least you have a 'tool' to use rather than simply, "is the light on top blue or amber?"
