- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Backhaul Broke?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Backhaul Broke?
Ever since updating from 2.3.1.44 to 2.3.1.60, my ethernet backhaul no longer connects. It only shows 5G backhaul. This happen to anyone else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backhaul Broke?
If it shows 5G then it's working. Unless your RBS is wired?
Has a factory reset and setup from scratch been performed on the system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backhaul Broke?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backhaul Broke?
What is the Mfr and model# of the ethernet switch in the configuration.
This is ethernet back haul.
Is Daisy Chain enabled? It should be disabled when ethernet connected between RBR and RBS. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backhaul Broke?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backhaul Broke?
@johnny5126 wrote:
I have one RBR50 connected in the WAN port going to a switch, and a cable going from the switch to a port on the RBS50. Looking at the connected devices in the past showed wired, but now it shows 5g.
That seems to be the culprit. The cable should be connected from RBR50 LAN port to the switch. Then RBS50 WAN port should be connected to the (same) switch.
Take a look at this link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backhaul Broke?
Daisy Chain needs should be disabled.
Ethernet with a switch configuration look similar to this:
Please confirm the model # of the NG switch? JPE16 doesn't pull up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backhaul Broke?
I have RBR50 and three RBR50s... Two RBS50s are hard wired and one is 5G.... Upgrade to firmware V2.3.1.60 and all is working perfectly.
