Orbi WiFi 7 RBE973
Reply
Backhaul wireless network
ekhalil
Master
Orbi is Tri-Band system. 3 bands are used: 2.4 Ghz band and two 5 GHz bands. I thought that the second 5 GHz band is used for the backhaul network.
Looking into the attached devices in orbilogin I see that the MAC addresses of the 2.4 GHz interfaces of the satellites are shown (connecting the satellites to the router) which I interpret as the 2.4 GHz network is used for the backhault network which is a bit wierd since this is a slower network and has less throughput.
Anybody has better knowledge about this?
Thank you
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 6
Guru
Re: Backhaul wireless network
The 5Ghz back haul radio information is hidden and is the wireless backhaul.
Message 2 of 6
ekhalil
Master
Thanks,
This is what I also think, but every nodes has 3 MAC addresses, why is the MAC address of the 2.4 GHz interface is shown as the backhaul interface between the nodes under <attached devices>?
Message 3 of 6
Guru
Not sure. maybe a cache or mis-naming problem in the UI. Others have reporting seeing the satellites in the connected clients list before rather than in the connected satellites list.
Seen in different browsers?
Might try a reset on the router and set up from scratch...Re-add the satellite and check...
Message 4 of 6
ekhalil
Master
Do you mean that you don't see the same behaviour? Which of the 3 MAC addresses do you see in your connected satellites?
Message 5 of 6
Guru
Just one satellite, however it's wired back haul.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1149 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
