Orbi WiFi 7 RBE973
Reply
Bad performance Orbi RBR20 with Unitymedia / Vodafone Station
mainhattan
Hi,
I am using a Vodafone Station with an Orbi20. Lately the wifi performance has dropped from about 200 to 50, whereby I signed up for a 500 line.
Please advise if you are experiencing similar issues.
Thanks & best regards
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 13
Guru
Re: Bad performance Orbi RBR20 with Unitymedia / Vodafone Station
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Message 2 of 13
mainhattan
Thanks for your feedback.
I am actually on the latest firmware version: V2.7.3.22
It seems to be that devices connect to 5G only if the device is really close (2m) to the Orbi. Otherwise the device will connect to 2.4G. Therefore the measured performance is very limited. I assume that the firmeware update has caused a different behavior as previously.
Message 3 of 13
Guru
Has a factory reset and setup from scratch been performed?
Please give feedback to the other questions...
Message 4 of 13
mainhattan
Yes - no changes and a friend of mine is facing the same issue.
Message 5 of 13
Guru
Really doesn't help answer questions that were asked.
So try reverting FW versions then.
Message 6 of 13
mainhattan
@FURRYe38 wrote:
V2.7.3.22
Vodafone Station
130 sqm
app. 10 meters each
no changes
no changes
Message 7 of 13
Guru
So does the ISP Modem have a built in router and wifi already?
Do you have Armor or Circle enabled on the RBR?
Message 8 of 13
mainhattan
Yes, it does.
Negative
Message 9 of 13
Guru
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 10 of 13
mainhattan
Thanks, but this does not solve the initial issue.
Message 11 of 13
Guru
What WiFi devices are you using?
Message 12 of 13
mainhattan
Mainly Apple devices and Samsung TVs.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1303 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
