Orbi WiFi 7 RBE973
Reply
Beam Forming and MU-MIMMO
RegDawg
Apprentice
I noticed these options unchecked along with "fast roaming" (I think thats it) in the UI. Should these be checked for better performance?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
webminster
Luminary
Re: Beam Forming and MU-MIMMO
There's no hard answer to that - it's more of a try-and-see for your environment.  Fast-roaming can cause issues for some clients (excessive roaming, disconnects).  Mu-MIMO requires client support, and there's a lot of clients that don't support it (and won't get any advantage).  The beamforming option you may or may not see a tangible benefit.
Some have seen stability issues on the Orbi with them enabled.  Some have not.  I personally have them off, as I saw no appreciable benefits in my home.  If you feel adventurous, you can enable, and turn them back off if you see issues or don't see a benefit.
Message 2 of 3
Guru
You'll have to test them out to best suit your needs. If you don't any or many MIMO supporting devices, then you can leave MIMO disabled.
I have Beamforming enabled and all is working well with my devcies.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2137 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
